I purchased a inexpensive 3-Axis low-g Accelerometer PCB of ebay that looks like it would be a good match to Picaxe. It is based on the MMA7260Q from Freescale but includes a 3.3 volt regulator so it can be run off a standard picaxe supply. The pcb format looks like it would interface rather easily - 3 adc connections and two or 3 digital connections to control it and the format should allow it to be plugged into a prototyping board.
While it would work well with a Picaxe running off 5 volts I can get better resolution if I used a Picaxe running at 3.3 volts to interface to it. I was thinking of using a picaxe 8 or 14m to interface to the accelerometer (running on 3.3 volts) but I would like to communicate to another Picaxe using a serial interface. Anyone with experience connecting two picaxes - one running on 3.3 volts and the other running on 5.0 volts over serial? I would appreciate any suggestions.
