My program is currently taking approx 1070 bytes.
Having read the following from the manual,Does this mean i am about to run into problems?
Or can the program take up to 4096 bytes without any problems?
Or will i have to split my program and load it into seperate slots and call the slot# when required?
However program slots can be combined into one ‘long program’ as long as the
following points are noted:
1) No gosubs (including the interrupt) can be shared between program slots
2) The gosub/return stack is reset when moving from one slot to another
3) Outputs and variables/scratchpad are not reset
4) The ‘run X’ command should be regarded as ‘goto to the start of program X’
