whiteoaks7
Okay, a lot of this has been gone through so forgive me but let me see if I've got this right. I want to use the Serial In pin (leg 6) on the 28X2 as a digital (binary) input. To do this I have to: (1) issue a 'disconnect' early in the program (2) ensure the pin is LOW before the disconnect is invoked. After this I can use the pin as a normal I/O it seems, however: (a) the simulator doesn't allow me to enter an input (the box displays a red RXD presumably to indicate the normal rxd is inhibited) (b) while part 1 of the manual tells me I can use the pin as digital I/O part 2 tells me I can only use it as a serial input (albeit serial under my control, not the processor's). Which is right?
Cheers
Cheers
