Hey Guys, NEWBIE question.. I have searched around but could not find anything really on this.. Please point me in the right direction if you could.
Last night I was able to get a MAX7219 working well with a 28x2 Picaxe.. I was using the hspi clk and hspi sdo connected directly to the clk and input of the max7219.. and it works well.
The question I have is.. Does the 20m2 have these same or similar outputs? I cant seem to find info in SPI out on the 20m2 models.. There is i2C, but from what I gather it is different. This is my first project using any of these protocols.
I was able to piece together some code by searching the forum,
I much rather use the 20m2 for the end project to do size and cost.. As well I don't need all the extra pins on the 28x2..
Any help would be greatly appreciated. As well If there is alternative code you out there please point me in that direction..
(I guess my main confusion is what pins do I connect the Max7219's Clk input, and Data input to on the 20m2, and is the code very similar regarding sending the data)
Thanks again
Steve
Thanks again
Steve
