I need to monitor the spare contact on a Finder DP relay but the other contact is switching a 240V contactor coil. I will use 20M of 4C screened cable with the screen connected to mains protective earth. The relay coil is switched by 24Vac.
Prospective circuit diagram based around optoisolator attached. I always feel uneasy about long cable runs going direct into a PICAXE (or even short ones where any inductive switching occurs nearby), but am just wondering if this is the most effective approach?
[The PICAXE at the other end of the 20M cable run is powered from a switchmode PSU to which I have added mains filter and 375V 220n X2 capacitor. 5V is then fed through another filter and transorb.]
Any suggestions welcome - sensible of course .
Regards
E.
Regards
E.
