I've been searching around but I guess I'm not using the correct terms. I have two 08M2's talking with each other with interrupts using serin/serout but need to 'store' data in the slave picaxe until the master is ready to use the data. I have ideas on how to increment the data storage location on the slave but do not know how to process the stored data when the master is ready to read the next input. I.E. the slave might have 10 variables that it stored from a keypad input in the time that the master implements a servo command (position) and then is ready for the next input. How do I 'increment' these storage values so I can clear them from the slave when received from the master all the while still inputting data from the keypad. I apologize if I am not clear in what I am trying to do. The comm code I am using is similar to http://letsmakerobots.com/node/3548
