the signal source to be measured is the output of a AD626 diff'l instr' amp. and has an output impedance of an ohm or less. what value of series resistor should be placed between its 10k load resistor and the -18X adc input for a reading ? i.e. what value of impedance is the -18X expecting to see for the voltage signals to its adc's ?
the signal to sampled w/ the adc is at a nominal 2 volt level with about 400 mV of 8khz blur centered above and below this level. how well does the -18X adc handle moving signals like this ? is there some sort of a hold-time requirement for the adc during which the signal does not change ?
the signal can be smoothed no further.
is it the custom in cases like this to take say, 50 samples, and then average them and call that the signal sample to save ?
what is going on is taking the voltage off a 20 milliohm sense resistor with 5 to 10 amps passing thru it on its way to a brushless motor. the AD626 lets you amp this input signal by 10 and LP- filter it.
but even after doing that the signal is still pretty noisy.
