Just received my first 18M2 chips!
Got a robotic car just waiting for it's new brain to arrive.
One of the new commands I have been wanting to look at is the PWMDIV64 command, so I set the chip up with an oscilloscope and started looking at all of the posible combinations of SETFREQ and PWMDIV.
Everything worked as expected until I changed chip frequency from M2 to M1. Instead of seeing the PWM frequency reduce by a factor of 2, there was a reduction of 4.
Also, changing the chip's frequency from 500KHz (SETFREQ K500) to 250KHz (SETFREQ K250), the frequency of the PWM output changed by a factor of 8 instead on a factor of 2.
Both of these issues occured with PWMDIV4, 16 and 64.
18M2 firmware 2.A, PE 5.3.1
I tested this on 2 different chips with the same results.
Dave E
P.S.
Have not tried to POKE registers to get frequency changes. Not sure if the registers to POKE are the same as the other chips.
Dave E
P.S.
