Quick question about the minimum required OPERATING (not programming) circuit for running a program on an 18m2.
Ive searched all around and read all the datasheets but could never really discern a clear answer about the new m2 parts. Hopefully im not being stupid and missed something obvious.
Basically, I built a little 'chip burner' PCB setup that permanently stays attached to my computer on my work bench. Im building several little remote control car modules where circuit board space is limited, so rather than take up space with a program-download header/plug, I just 'flash' the PICAXE with my chip-burner on my work bench, then transfer the PICAXE/plug it into the DIP socket on the car controllers circuit board.
Obviously on the older pre-m2 PICAXE chips the serial-in pin had to be tied low with a 10k and 22k resistor, otherwise the program would not run properly.
SO whats the deal with the new 18m2? I know the serial-in port can now be used as an input when the program is running and the PICAXE isnt being reflashed.......so does that mean that the 18m2 does NOT need any 10k/22k resistors on that serial-in pin to make the program run correctly? Can the pin be left floating? I know that you arent "SUPPOSED" to leave any pins floating, but on the hundreds of other (non-m2) PICAXE circuits ive made, as long as the serial-in pin is tied low with the resistors, ive never had a problem leaving other in/out pins floating.
Anyway...cliffnotes: does the PICAXE 18m2 need pin 3 tied to ground with resistors in order to function properly, or what is the deal with otherwise telling the PICAXE 18m2 to use that pin as a general purpose input???
thanks
Ben
thanks
Ben
