The website says that the 14M2 datasheet is the PIC16F1825. But I see the 14M2 has ports C0-5 and B0-5, whereas the 1825 has ports C0-5 and A0-5 meaning that the pins are named differently and in different positions.
Then I looked at the 18M2 = PIC16F1847, and compared it to "PICaxe 18M2 SFR Data Ver_A.pdf" from here :- http://www.picaxeforum.co.uk/showthread.php?11514-PICAXE-Memory-Map-and-SFR-Details-Chart/page2 Post# 13. - nice chart.
I notice that SFR locations differ ie. SSP1CON1 in the 1847 datasheet is at $215 but in the "PICaxe 18M2 SFR Data Ver_A.pdf" it is at $95.
So I am confused on several counts.
1. Why the different port/pin designations?
2. I don't understand SFR and cannot find out how correctly calculate the Bank# etc. ie. how did $215 become $95?
3. Is my coding attempt anywhere close?
I am interested in trying to use the hardware SPI port. Here is the code as of now. I suppose that I have learnt quite a bit doing this exercise, but it is coming to a frustrating ending. So any guidance and hints will be gratefully accepted.
' initialize the SPI module to have idle for clock low, send at middle of clock pules
' transmit on idle-active, use clock/64
' also needs to set the SS and SPI pins to proper outputs
' symbol OSCTUNE = $98
symbol SSP1BUF = $91 ' or $211 ??
symbol SSP1STAT = $94 ' $214
symbol SSP1CON1 = $95 ' $215
symbol APFCON0 = $11D
symbol APFCON1 = $11E
symbol TRIS_A = $8C
symbol TRIS_C = $8E
Main:
Gosub InitSPI
' debug
Gosub WriteToSPI
' debug
Goto main
InitSPI:
' B3 SCK0 output, B4 SDI input, B5 SDO output
'76543210
let dirsB = %11111111 ' set port pin directions
' let dirsC = %11011111
b1 = 0
pokesfr b1,SSP1CON1 'turn off module, in case it was on
pokesfr b1,SSP1STAT 'send at middle of clock, transmit on idle->active
b1 = %00100010
pokesfr b1,SSP1CON1 'enable MSSP, idle is low,clock/64
b1 = %0
' pokesfr b1,APFCON1 'alternate pin config
WriteToSPI:
b1 = $55
pokesfr b1,SSP1BUF
pause 50
