Short version:
The manual says I can use dirsc with a picaxe 14M (or high portc 3) but I cannot!
I get "Error: 'let dirsc' command not supported in this mode!"
(yet dirs is okay; it is like it is checking 8/8M syntax, yet it is certainly directed to use 14M syntax).
Long version:
I have a picaxe 14M (firmware 9.B) connected and told the programming editor it is a 14M (even tried a #picaxe 14m).
Appendix C of the manual1.pdf (Version 6.0 04/2007; the one that comes up when I click on "Help" within the programming editor, which is version 5.1.5, syntax DLL 131072 if that helps), says:
Using portc pins as outputs
Any portc pin can be configured to be used as a digital output.
To convert the pin C3 to output and make it high
high portc 3
To convert the pin C3 to output and make it low
low portc 3
To convert all the pins to outputs
let dirsc = %00111111
Also in manual 2, page 94, the dirsc is for the 14M.
Yet manual 2, page 13, doesn't mention dirsc nor dirs for the 14M (does mention dirs for 8/8MM and dirsc for 28X2), and when compiling code with either dirsc or portc I get "command not supported in this mode!" errors.
Mark
Long version:
high portc 3
low portc 3
Mark
