08M2 and DS1631 Control Register
PADJ
I'm using a 8M2 to read temperature from I2C DS1631 and format as serial data for a remote PC. Simple conversion from published arduino code, but the 1631 requires write to a control register to start the conversion.
No data is involved, just needs 2 bytes sent - the device address and the register ($51) location.
The published code does this
Wire.beginTransmission(DS1631_ADDRESS);
Wire.write(0x51);
Wire.endTransmission();
I tried hi2cout $51 - but this gives syntax error. Can this be done with the 8M2?
PJ
srnet
To be expected, thats not the format of the hi2cout command ...................
Perhaps you want to use;
HI2COUT location,(variable,...)
As described on page 74 of manual2
PADJ
But there is no variable to be written!
Edit:
Tried
hi2cout $51,() - Syntax error
You can send single bytes, and don't forget hi2csetup first
hi2csetup i2cmaster, DS1631_ADDRESS, i2cbyte, i2cslow
hi2cout ($51)
hi2cin $AA,(b20,b19)
PADJ
hi2cout ($51)
Thanks technical - I didn't realize that 'location' was optional, but now I've RTFM (again) it's obvious.
In fact if I'd downloaded the latest manual I would have seen the logic plot as well!
Lesson learned, and I'll wire it up tonight if the snow doesn't bring the power down <g> and report back.
UPDATE That seems to do the job! Thanks again. Now for the fun part.
PADJ
A year later, and time to add more sensors.
To do this I need multiple hi2csetup statements, so to minimize code space can DS1631_ADDRESS be a variable?
This passes syntax OK, but I don't have the parts yet.
for b0 = $90 to $9E step 2
hI2CSetup I2CMASTER,b0,i2cslow,i2cbyte
next
There should be no problem setting the address via a variable. In almost all cases, wherever a pin identifier, number or named constant is usually specified, it can be substituted by a variable holding an appropriate number.
In the few cases where a variable cannot be used the compiler will give an error when a variable is used.
PADJ
Interesting, thanks. So if I used a 20M2 with 8 DS18B20 instead, could I do something like this?
for b0 = b.0 to b.7
readtemp12 b0,w13
next
