Using the above units together, they work fine as long as the Calibfreq on the 08m2 is set to -15 and the RST pins are briefly reset on the AXE033b.
This will work ok for around 10 hours at room temperature and then spurious characters start appearing. If the temperature drops to around 12c then the problem seems to start sooner.
Simple circuit with 7805 supply and 1.2k to ground on Serin pin (pin2 on chip). Decoupled by 100uf and 0.1uf ceramic.
Direct connection to serin on AXE033b
The pair work faultlessly if connected by I2C method.
Any guidance
Any guidance
