I just came across some references to "mixture control solenoids" and am intrigued. Everything I could find addressed automotive applications and the solenoids used there are far too big for my needs.
I have a requirement to slightly adjust air pressure for a project and, originally, I was planning to try to use a servo-driven needle valve, but am now wondering if this is a viable alternative that is mechanically more simple than the needle valve solution.
I am looking for the smallest possible solenoid valve that will control no more than 0~15psi with minute airflow. I would use an 08M to pwm the solenoid to control pressure on the downstream side. My reading suggests that the pwm rate for this sort of control in an automobile is only about 10Hz.
Has anyone tried this sort of control, using a picaxe to take a control signal and translate it into appropriate duty cycle to modulate a solenoid?
