I purchased the 08m starter kit and wired it up. I am using my regulated supply set at 5 volts and switched to monitor amps. When I attach the board to my PC and turn on the 5 volt supply the amp meter jumps to well over 1 amp. This is without the picaxe in place. Is this normal?
I have checked the output from the PC plugged into the connector but without the 5 volt supply on and am reading -10.80 volts on pin2 of the ic socket.
