Hello.
I hope someone can advise on this ...
The manual, part 1, states for the 08M -
'Pin 0 (leg 7) is used during the program download, but can also be used as a normal output once the download is complete...If you are making your own pcb you can include a similar jumper link or small switch, or you may prefer to connect the microcontroller leg to both the output device and the program socket at the same time. In this case you must remember that your output device will rapidly switch on and off ...'
Having got a circuit working fine on a prototype board (with the jumper) I have made a custom board (without the jumper).
I have a piezo sounder sharing the output (resistance about 25r) and the existing program and outputs execute perfectly'
But now the Programming Editor starts the 'Connecting to hardware' process then reports 'Error-hardware not found on com6' when I try to update the software.
I can hear the connection attempt on the sounder, so am happy the configuration is correct.
As it would now be monumentally awkward to access the board copper-side and there's a slim chance the fault is elsewhere, can anyone confirm that a piezo sounder is not a good share for this output or if there is any temporary bodge I can make on the component side to re-program the 08M when required?
Many thanks,
Laurie Townsend
Many thanks,
Laurie Townsend
