I've built several projects using 08M and servo motors and I've never run into this problem before.
I put a sertxd command in the initailization portion of my program to verify that the chip is resetting.
The chip and servo are on seperate regulated power supplies with large filter caps and a .01 mfd cap across the power pins of the chip.
The only thing I can think of is a cold solder joint but thought I'd ask for more opinions/ideas which I may not thought of.
