Variable capacitance buttons = anything nowadays that is touch sensitive.
So how do we do it with a PICAXE???
Here are a few sites:
http://www.analog.com/static/imported-files/Data_Sheets/AD7148.pdf
http://en.wikipedia.org/wiki/Capacitance
http://en.wikipedia.org/wiki/Voltage
http://physics.bu.edu/~duffy/PY106/Charge.html
http://www.eskimo.com/~billb/miscon/voltage.html
Capacitance is what we want to measure.
Capacitance is Charge/Voltage.
Charge is number of electrons relative to number of protons.
Voltage is totally relative (well explained in last link, paragraph = "Potential Energy vs. 'Potential' ".
We could use that chip in the first link but it isn't very compatible, blo... I mean very hard to understand and frankly, feals too much like giving up.
I do know this: When you put your finger on an iPod clickwheel, you are putting your fingertip near to a charged mesh. At the point near your finger, the meshes' charge increases. On the other side of the circuit there are a series of pads that measure that change in charge. However, we all know it is very hard for a device to just measure something without anything to compare it with (+Vcc). So instead the iPod measures the capacitance which is also relative to voltage (C=Q/V). This must allow the device to calculate the charge.
So if we can measure the capacitance of a pin on a PICAXE then, well...
