yusuf.businessmen
Hello guys...
I am working on automated tankfiller project and I have attach the circuit diagram but I want the program code as I diserve to work...
The working of the circuit I prefer is :
As the water goes below the low level sensor it will start motor pump and wait for 10 minutes... in between 10 minutes if the water goes little bit higher so that it touches low sensor then the motor will keep on running untill the tanks becomes full (so that water touches full sensor) if the tanks becomes full then it will stop the motor pump...else if the water doesnt comes lit bit higher so that it can't touch low level sensor between 10 minutes then motor pump will turn off... and it will start again after 1 hour and this process will repeat.... untill the tank becomes full..
friend I want this same concept so please help me how should I accomplish this.....
Please modifiy and complete this circuit diagram with program code.....
Thanks in advance....
