Hi All,
I made a simple timer circuit with a picaxe 8 pin. Outputs are to a beeper and an LED. I only defined outputs c.2 and c.4, pins 5 and 3. I am mounting it on a small circuit board on a socket. It doesn't work or has random outputs. When I put the programmed chip back into the proto board pcb (with the programming resistors, jumper, etc.) it works.
I know that some inputs should be grounded. Can I just ground all the unused pins? Do I have to define the other pins in the program as inputs or outputs? I don't need to program the chip in the circuit so don't need the stereo socket or pull up resistors.
Thanks,
John in Arizona
Thanks,
John in Arizona
