I am considering using a continuos rotation servo in a project I am planning..
I have used normal servos in previous projects without a problem as they are easy to control.
In a previous version of the project I used a standard servo and a couple of levers to
create a form of linear actuator. However space constraints prevent using this approach again.
The question is what is the best way to control a continuous rotation servo?
What code would you use to say make the servo rotate clockwise for say 2 or 3 seconds?
Also how to reverse the rotation. The servo will be used to make a simple linear actuator
using a drum and pulley, (controlling speed, distance travelled and direction).
I have some ideas about how to proceed but would welcome forum members views.
Clockwork
Clockwork
