keyturbocars
Hello,
Someone recommended the Picaxe processor to me and this forum as well. I have a 2kW wind turbine system and it is set up to charge a large 48V DC battery bank. Once the battery bank is charged, then I have a diversion controller that I use to dump the extra electricity into an auxillary hot water set up with special 48VDC heating elements. The 80 gallon hot water heater has a special thermostat as well to shut off the dual 1260W DC heating elements at 120F.
The controller that I use to divert wind power at a set battery bank voltage (to prevent overcharge of the batteries) is made by a small company called Coleman Air. I think it's a one-man business. The controller is not working exactly as I need it to work. They guy is obviously very smart with electronics; however, he did not want to help me with this (he's too busy I think). He suggested I look into a Picaxe programmer and try to do it myself.
Now, I'm not an electronics guru. I have some technical background with a mechanical engineering degree, but I am not naturally strong with electronics. The idea of programming a microprocessor is intimidating to me.
Here are some pictures of my wind turbine set up.
http://www.facebook.com/album.php?aid=31445&id=100000264867099&l=6c791ef013
I also attached a picture of the controller circuit board. It controls a large 440A relay. The way the controller works now, it checks battery bank voltage every 5 seconds. When the battery voltage reaches around 52V, the controller then begins to check battery voltage every 1 second. When the voltage reaches a preset level (I have it set to around 56V now), then the controller energizes the relay coil and starts to divert power to the auxillary hot water heater. When the voltage drops to a certain level, the relay is turned off and the sampling continues every 5 seconds until the voltage rises to 52V at which time it starts to sample more frequently at 1 second intervals.
What usually happens is when the wind is blowing hard, the battery voltage can rise quickly when the battery bank is fully charged. The controller sample rate is so slow that the voltage overshoots the set point on the controller. This results in a secondary controller being tripped inadvertently that dumps power to air heating coils. This is not wanted. The second controller is set up to dump power at 60V and is only a safety backup to make sure that the batteries are not drastically overcharged in the event that the primary controller is unable to dump power to the hot water heater. I may have the primary hot water controller set to dump to 56V, but it will not trip until 62v because of the overshoot. This is the problem with the controller. The 5 second sample rate is way too slow. By the time it switches over to the 1 second sample rate, it's too late. The voltage has overshot and the secondary controller is being tripped on/off excessively. There is nothing that I can do to adjust the trip point of this secondary controller. All I can tweak on the primary hot water heater controller is a small POT that changes trip point. If I try to lower trip point to avoid triggering the secondary controller, then the batteries are undercharged and this is not good.
The creator of the controller said that the microproessor can not sample more often than 5 seconds because there is a green LED light that flashes to show state of charge of the battery bank. It is only at 52V that the blinking green LED turns steady state, and then the microprocessor is supposed to be able to increase sample rate to 1 second. It is my feeling that if the sample rate could be 1 second (or more often) all the time, then this overshooting problem could be minimized. Every 5 seconds is not often enough. I would be happy to loose the blinking green LED function in order to be able to 1 second sample rate all the time.
Is this something that the Picaxe would enable me to do?
I feel really intimidated and I don't know if this is something that I can/should try to do. It makes the most sense to me that the creator of controller would be best equipped to make this small tweak since he understands this controller better than anyone else in the world. He said that he would charge a minimum of $500 and even then he would not have time to do it for a long time. I might as well throw away the controller and buy something else if I have to spend 2X what the original controller cost just to have a small tweak made to the programming. He does not want to help anyway. He's too busy with other projects.
Those of you that are familiar with the Picaxe microprocessor, would something like the 08M work for this?
Thanks for your opinions,
Edward
Edward
