Manie, it's so easy... or should I call you Eliza?
Yes, I had an education too!
The LVP bit configuration register CONFIG4L enables
low voltage ICSP programming. This mode allows the
microcontroller to be programmed via ICSP using a
VDD source in the operating voltage range. This only
means that VPP does not have to be brought to VIHH,
but can instead be left at the normal operating voltage.
In this mode, the RB5/PGM pin is dedicated to the programming
function and ceases to be a general purpose
I/O pin. During programming, VDD is applied to the
MCLR/VPP pin. To enter Programming mode, VDD must
be applied to the RB5/PGM, provided the LVP bit is set.
The LVP bit defaults to a (‘1’
from the factory.
Note 1: The High Voltage Programming mode is
always available, regardless of the state
of the LVP bit, by applying VIHH to the
MCLR pin.
2: While in low voltage ICSP mode, the RB5
pin can no longer be used as a general
purpose I/O pin, and should be held low
during normal operation to protect
against inadvertent ICSP mode entry.
3: When using low voltage ICSP programming
(LVP), the pull-up on RB5 becomes
disabled. If TRISB bit 5 is cleared,
thereby setting RB5 as an output, LATB
bit 5 must also be cleared for proper
operation
If Low Voltage Programming mode is not used, the LVP
bit can be programmed to a '0' and RB5/PGM becomes
a digital I/O pin. However, the LVP bit may only be programmed
when programming is entered with VIHH on
MCLR/VPP.
It should be noted that once the LVP bit is programmed
to 0, only the High Voltage Programming mode is available
and only High Voltage Programming mode can be
used to program the device.
When using low voltage ICSP, the part must be supplied
4.5V to 5.5V, if a bulk erase will be executed. This
includes reprogramming of the code protect bits from
an on-state to off-state. For all other cases of low voltage
ICSP, the part may be programmed at the normal
operating voltage. This means unique user IDs, or user
code can be reprogrammed or added.
Or, to cut it short as I know you won't read that lot:
For ICSP use a programmer.
For PICAXE-like programming, bootload it first then programme it serially using Tx/Rx.
(Which will require a MAX232 or transistor inverter circuit)
Of course, you'll need a programmer to chuck in the bootloader - oh dear!
Still not as easy/inexpensive - so stick to PICAXE.
