I have a PICAXE project which interfaces 2 different pieces of equipment.
The equipment on either side provides a 5V VDD in addition to input and output signals.
I want the PICAXE to be operational if (1) only 1 of the 2 interfaces is connected and powered-up, if (2) both are connected but only 1 is powered up, or (3) when both are connected and both are powered up.
I can't simply short the VDDs together, because in case (2) above, the powered side would drive power back into the unpowered side.
I could use diodes in a "T" configuration, but I don't want to incur a diode drop on the VDD seen by the PICAXE.
So... attached is my idea for making this happen (each emitter comes from the VDD of a different interface; the "dotted" collectors drive the VDD of the PICAXE).
Does anyone see any gotchyas with this?
