Boondocker
Hello,
I’m considering purchasing the SCP1000 D11 pressure sensor, the i2c model, to measure barometric pressure with a Picaxe 18x chip. This sensor is available on a PCB mount at Digkey. http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=551-1044-ND
Will this device work simply using i2cslave, readi2c and writei2c commands to avoid “bit-banging”? Just like using the DS1307 clock chip.
I’m a novice just started studying i2c communications and uncertain about reading the data sheets properly.
http://www.vti.fi/midcom-serveattachmentguid-e9735f5baea5692c3b9753f9069511c7/scp1000_product_family_specification_rev_0.08.pdf
What I can figure, the slave address is %1001001 and the read pressure (16bit) address is %10000000.
I hope using this sensor will be as easy using the example code below.
I2slave %1001001, i2cfast, i2cword
Pause 60
Read i2c %10000000, (w1)
Thanks for your comments and advice.
Pause 60
