USB, once more
Windows does not use COM0. It must be 1-255!
The pinout of the cable, with resistors for the download circuit, is all explained in part 1 of the PICAXE manual - see the USB and serial download circuit pages.
I don't want to belabor the isssue. This reply is just in case other users may have uncertainties regarding the USB port.
Just so you will understand my dilemma, I had read Section 1 – 5, “At a Glance-Download Circuit”, which shows a male plug with numbers 1,2,3 but does not match these numbers with anything, nor, does Section 1-30 “USB Download Circuit”, or Section 1-32, “Enhanced Download Circuit”. However, upon closer inspection, I find that Section 1-31, “Serial Download Circuit”, does identify (I believe, although I am not certain): 1 = output from picaxe = sleeve, 2 = input to picaxe=mid-band, 3 = ground = tip. This happens to be quite different than my 9-pin, serial-to-male connector, for which the ground is the sleeve - all of which goes to show, “different strokes for different folks”. So, I will trust the diagram in Section 1-31, even though I feel tentative about it, since all of my experience with audio equipment has the sleeve at ground potential.
With regard to Windows XP, System information, “hardware”: Under “Universal Serial Bus Controllers”, it identifies the USB as “Location 0”. However, under, “Ports”, the USB serial port is identified as, “Com 6”. Most of my USB devices operate seamlessly. However, I do have one that won’t work unless I plug, “Com 6”, into its system. I assume that picaxe will be similarly demanding.
