I have a verizon USB720 (qualcomm 3G CDMA) broadband access pod.
The cable had two USB (A) plugs on one end and a USB (A) receptacle on the other end.
The reason for the two plugs on the one end is that you can get more than 500mA with both plugs inserted into two USB ports.
Is this simply because of the parallel cable connection, or MUST the USB device request more current from the hub?
I am somewhat familiar with the initialization current limit of 100mA and the requested operating limit of 500mA,
but am unsure how this device actually has access to the full <1000mA.
Does anyone here know how this functionality is obtained?
Can it be obtained by a powered hub?
I want to have ONE connection supply my programming signals and the 5V, 3.3V and 3.0V(as required) for PICAXE development.
To that end, I am looking to make an adapter that can mix these signals/voltages for my dev boards.
Thanks.
k
Thanks.
k
