retepsnikrep
I'm trying to drive the SV2000 video chip which was mentioned in an earlier thread. I may be misunderstanding the serial comms as I have the chip configured as per diagram 1 TTL.
I'm trying to drive it directly using serout with an 8mhz 18x to provide 9600baud data but I get nothing
I've tried inverting both Pic output and Sv2000 input
Change calibfreq up and down
The chip appears to be working as it has some signal at the output and it's internal watchdog is ticking. The 18X is outputing the data I can see it on the output pin. Do I need any conditioning? or can the Picaxe be connected directly to the input of the Sv2000? It says Max232 ttl compatible.
Any ideas
http://www.speechchips.com/shop/item.aspx?itemid=5
My code is
setfreq 8m
serout 4, N4800, (27,42)
Should display welcome screen
Thanks
Any ideas
My code is
setfreq 8m
Thanks
