Apologies if this has been covered before.
I have a flowchart in logicator and i pressed 'program pic' with the serial lead plugged in and the battery connected. I am using the axe 002 picaxe 18X started board as the programmer as it has the socket and power etc. When i press program the box comes up to program it and at the same time a program called ic-tester tries to install behind it. If i move the first window out of the way it is asking for a location for the ictester program. Well i neither know what the ictester is nor have the disc. I tried putting the disc that came with the starter board into the drive but the program did not find the file it was looking for on it.
Do i need this ictester, as it seems to fail without it and if so is there another way to install it?
Any help would be gladly received.
Many thanks
Dom B
Many thanks
Dom B
