This thread is for informational purposes only.....
Some time ago I had inquired here regarding execution times for simple commands like 'High 0' or 'Low 0' and seem to remember having been told that these commands take approx. 1 mSec to execute on an 08M.
I did some measuring this evening on an 08M at 4 MHz and obtained the following very consistent results at room temp (about 90F in my office right now):
~250 uSec going from high to low & vice-versa on Out 0;
~ 550 uSec for ADC 8-bit conversions, regardless of channel
This timing remained the same with supply voltage at 5V or 3V, and applying a soldering iron to the top of the plastic package (surprisingly) did not noticeably affect the timing.
I will probably test 10-bit conversions also, in case anyone is interested I could post the results here. And, while I have the test setup, if anyone is interested in any other rudimentary timing measurements, I could also run those; if so, let me know in this thread....
Odessa.
Odessa.
