George Sephton
Im having real difficulty getting my head round this so I wondered if someone could clear this up for me.
I'm about to have a pcb fabbed and i'm thinking about through hole soldering...? Surface mount is easy as there's one side of pads so its easy to know where to solder, but through hole has 2 layers (in my case) and i'm trying to understand the pads. Are they connected on the top and bottom or not?
Take a look at this photo: http://www.sparkfun.com/commerce/images/products/00114-03-L.jpg
not that there is not bottom layer, it everything is on the top, so I've been assuming pads on the top and bottom aren't connected, ie if you have an LED the traces will need to be connected to the bottom pad cos obviously you can't solder to the top pad, however looking at this image of the pcb assembled, you can see very few of the components are soldered on the top: http://www.sparkfun.com/commerce/images/products/00114-04-L.jpg
I'm going to order with BatchPCB and my question is this? Are the through hole pads joined? Because at the moment all my through hole stuff has traces on the bottom layer connecting to the bottom pad, no top are uses and if it needs to be on the top a via is used dircetly after the pad...so do I need to do this or not? Can I have traces going to the top pad of say an LED and solder the LED from the bottom and still allow it to work?
Thanks,
George S.
Thanks,
George S.
