Im looking at the ratings and itll switch with 6v so you should be ok. On a side note these relays are pretty damn hefty, they weigh 86g or for Americans like me, 1/5th a pound!! Id think for what your doing you should start looking at Bosch automotive relays. If you can post your electrical requirement I could probably help you find a relay thats small and would work great, has a high life expectancy and they are dirt freakin cheap. They can handle most any DC voltage supplied by a battery (within reason) and they can survive in what Id consider the worst conditions possible. Im talking fire, high shock loads, vibration ect. They are rated at 30A @ 12v and can switch 24v loads.
How are you planning to trigger the relays? Are you pulling them to ground or with a positive trigger? Id recommend pulling them to ground but I dunno what your plans are. If you are using (2) 12v batteries to get to 24v Id suggest powering the coil at 12v (trigger side of relay) and pulling them low via a transistor. Then you can switch the load to your motors at 24v. I wouldnt suggest using a positive trigger for the relays and although the coil on the relay you linked to will switch at 6v, its better to do all your relay switching at 0v since everything has common ground, regardless of the voltage levels. Might wanna give it some thought though of using an auto relay as they can switch 24v. There are DPST variants also just not as widely used.
