I know this has been discussed before but I can't find the answer to my specific question.
I need to run the timer to provide a long-term timebase for an application. In the main program loop I'm using many hi2c commands, I'm not using any of the timing sensitive non-hardware commands (e.g.readtemp). At the moment every so often the i2c bus becomes corrupt. My 28X1 is version A.5
I assume that this is because an i2c interrupt is lost during the processing of a timer interrupt as per previous posts on the forum
I'm also assuming that the internal hardware timer interrupt occurs when the minor tick variable overflows from 65536?
I'm using the t1s_16 set up for the timer but running the processor at 4Mhz so the timer variable updates every 4 seconds.
My main processing loop takes just over a second to complete.
My question therefore is:
If I wait in code for the timer variable to have just ticked as follows:
w0=timer
w1=timer
loop until w0<>w1
Can I then be certain that for nearly 4 seconds there will be no underlying timer interrupts that can conflict with the hi2c commands allowing me to process my main loop before going back into the wait loop
Thanks
Peter
w0=timer
w1=timer
loop until w0<>w1
Thanks
Peter
