Durham_Biomed
Hi, I'm using a 40X1 Picaxe chip and I was wondering if the serout command can be used with pins other than 33 - 40 (Output 0 -7)? or is it possible to use it with pins that you assign as outputs?
Thanks
Thanks
The serout command is used to transmit serial data from an output pin of the
microcontroller. It cannot be used with the serial download output pin - use the
sertxd command in this case.
Pin specifies the output pin to be used.
While the 40X and 40X1 have an additional 8-bit port, called portc, the use of this port is restricted to simpler commands like:The serin command is used to receive serial data into an input pin of the
microcontroller. It cannot be used with the serial download input pin, which
requires use of the serrxd command instead.
Pin specifies the input pin to be used.
