Hi all
I've got a circuit working (28X1 at 16Mhz) that amongst other things parses a 4800 baud GPS feed (could also be set to 9600) using the qualifiers on the serin command to select the message of interest ("$GPRMC"). This is really easy to code and works very well but I want more CPU power to do more complicated processing between messages (every second) so would like to move to the 20X2 at 64Mhz.
Is it possible to run a 4800 or 9600 baud serin on a 20X2 at 64Mhz? If so can anyone let me have the numerical values for N4800_64, T4800_64, N9600_64 and T9600_64?
I know I can code all this from first principles using hserin but I only want the one message and don't want to have to code to ignore the others unless necessary.
Apologies if this has been covered elsewhere but I couldn't find anything with search.
Thanks
Peter
Thanks
Peter
