Hi there,
I have a serial pic programmer that I believe is based on your design. I can connect to it using your software.
Anyway, I had a problem; it was saying 'chip type is not found' (with a 16F627 in it) and refusing to program. The problem, I found, was solved by increasing the power supply voltage.
Anyway, yeah, you could edit the error message to say 'part not detected... check programmer power supply voltage' or something.
