It occurred to me recently that when polarity is reversed on a DC motor for/via direction control then the motors metallic external housing/body which is usually ground becomes part of the +12V supply.
If the motor is attached to a sheet metal chassis as is the case with my feeder then the whole feeder becomes +12V and any other parts of the circuit that are grounded to the chassis would be shorted out. I guess this is all pretty obvious stuff. Correct me if I haven't got it right.
I presume the way to deal with this is to electrically isolate the motor from the chassis with non conductive mounts? Robot builders must have to deal with this sort of issue regularly.
