I have a task which I have divided in proportion stepper
since I do not know where the individual date elements are
day, month & year and maybe kind of off checksum
This chip uses as a time lock on a battery pack in a UPS system
I want a change it.. after I change battery so it does not get by and say "You is out off battery life"
I have a 24c02 from an old battery pack where I know what the date is in DD: MM: YY
I have created a setup which I believe can be used
switch must be used to activate read function
there are some who can help with some base code
based on picaxe 20x2
1 step
read content from 24c02 add 0 to add 255
send it to the terminal as HEX
00: xx.xx.xx.xx.xx.xx.xx.xx
08: xx.xx.xx.xx.xx.xx.xx.xx
FF: xx.xx.xx.xx.xx.xx.xx.xx
This will be used to find the right positions for the data that I need
2nd Step
after I know where my data is
should I change this and write data back incl new checksum (when I found out this algoritne now)
1 step
2nd Step
