Did hot wire anemometers get a mention? These have no moving parts, & work by noting R value changes occurring in response to the cooling of the heated platinum wire by passing breezes.
Forget costly & fragile platinum-Carl & Jerry =>
http://www.copperwood.com/Carl_and_Jerry-V12N03-A_Hot_Idea.pdf latched onto a cheaper approach back in the 1960s using matched thermistors in a 4 resistor bridge array. Factor in PICAXE number crunching via a simple R difference lookup table (+ perhaps of course data logging), & there you have it. For those of us weaklings fortunate enough to be clear of Gustav's Gulf Coast fury,calibration out the window of a moving car my suffice.
Winds close to the ground are usually buffeting & scudding from every which way, & wind turbines should hence be elevated into laminar ("smooth") flows. A thermistor setup on a tall pole would probably be more rugged than a DIY motor-gene. Brush wear naturally would no longer be an issue!
EXTRA: Pulses you say. I've had a lot of fun fooling bike computers into reading Amps & Ah (which are shown as speed and distance). The wind run resource,which is really what you most interested in when small scale wind farming,could be -ah- a breeze.
