Hi guys,
I would like to build my own lights switch for my RC car. I have a 4 channel transmitter and 4 channel receiver.
I have two questions:
Q1: I would like to have brake lights on my RC Car. Each of receiver channels has 3 pins. Pin1 = signal, Pin2 = +5V, Pin3 = GND. On the Pin1 are pulses between 0.75ms to 2.25ms where 1.5ms is neutral. I have done the brake light with the PULSIN command. (connected to channel 3). But when I quickly move the steering stick (channel 1) or quickly move the accelerate / brake stick (channel 2) the brake light quickly flashes. It looks like a noise is comming from the transmitter potentiometer or is generated on receiver. How can I remove the noise (or the jamming)? How could I change the program code? Or is it a HW problem?
Q2: I would also like to have front/tail lights, fog lights and hazard lights. I would like to control them via 4th channel. So when I move the 4th channels stick from neutral to left one time, the front/tail lights has to switch on, when from neutral to right one time, the hazard light has to switch on an whet from neutral to left two times, the fog lights has to switch on. If you want to switch off som of these light you have to repeat the step when switching it on. I have tried it with PULSIN and COUNT commands but I was unsuccessful.
I am sorry about my english, I am not native.
Ask if you have question or you need to describe more in detail
Thanks
Geenius
Thanks
Geenius
