Programming Editor version 5.2.5 is now available to download from the software page. This release fixes a couple of issues and has a much improved serial over TCP/IP feature.
5.2.5
Ameded debug/simulation variable name list to also show variable number
Fixed issue with owin/owout in latest 28X1 compiler
Fixed issue with calibadc in latest 28X1 compiler
Added missing input/output definitions to 20M compiler
Added extra baud rate symbols to X2 part compilers
Updated assembler mode screen display options
Fixed issue with Ring Tone Wizard importing some RTTTL files
Corrected the following simulation issues:
- hi2csetup not setting flags correctly for on-screen EEPROM emulation
- adc simulated incorrectly in flowchart mode for 20M
Updated Serial COM port over Ethernet system:
- Improved installation procedure
- Virtual COM port is now shown in Device Manager
- Wizards at both end simplified
- Improved reliability of TCP connection by changing to Telnet format
- Added full Vista support and Vista signed drivers
- (Note that if already using this feature you must stop old sec_service.exe service before upgrading)
