Hi forum,
I have a problem connecting my desktop (Dell Dimension 9200) to the Picaxe AXE110P datalogger board for programming
I have an older laptop (Dell again) and with that I can connect without problems both using the serial or a USB port.
I am using a serial cable with the serial to USB adaptor.
On the desktop I have installed the cable drivers and connected to the Picaxe, queried the Picaxe for model and received a response (18X).
I was using batteries at first. I have built a 5V voltage regulator but no luck. I have performed all the checks recommended in the documentation and they all pass:
Now,
1) what possible reasons could there be for the different behaviour on the two computers?
2) Is it possible that I might need a 232 circuit to boost the voltages? (MAX232 or equivalent)?
3) Other suggestions?
Thanks in advance
Riccardo
I have done all checks
Now,
Thanks in advance
Riccardo
