It sounds like 0J0 is a PICAXE but 5UH is a blank PICmicro. If this is the case then the 5UH will not work with the PICAXE download interface.the program works but do not recognize the microchip 12F683 (5UH).
but i have another chip of picaxe 12F683 (0J0) is old and it works.
We think that the 5UH is the makers serial number. It does not indicate that it is a Picaxe 08. It is more likely that you have 2 different items - A picaxe 08m that you can programme and a normal PIC that you can not programme with the Picaxe system.Explain everything. I buy these chips in the electronics store PIC12F683 (5UH) but when trying to implement the circuit does not discharge me iva then probe with PIC12F683 (0J0) and if that hiba. (Editor Programmming ...) So I wondered if there would be some way whether or not the program could PIC12F683 (5UH) or they do not serve as PICAXE 08M.
The circuit is the 2 resistors and which discharge to the COM jack but I get the error, verify several things current, if a picaxe if connected ..... when trying to download!
Looking at the photograph and relative to the circuit borad artwork there is a possibility that the PICAXE chip may be installed the wrong way.I gonna put the message error and image of test circuit
That website is advertising a standard PIC chip and NOT a PICAXE 08M.
You can't, how would rev ed (the makers of PICAXE) make money?How i make to install firmware in a standard PIC12F683
