djsoftlayer
Hello, whatever takes maximum to the picaxe at 4mhz to execute a command? What would be a maximum time for the common commandos?
It is the function PAUSE precise in small values? , I am executing the command PAUSE 2, and I suspect that the pause is smaller than 2ms, is that possible? Note: I do not have oscilloscope.
With respect to the last question, I am using the following code:
inicio:
If pin7 = 1 Then contar
GoTo inicio
contar:
pause 2
inc xx
If xx >= 250 Then
inc y
Let xx = 0
GoTo calcular
End If
If pin6 = 0 Then contar
If pin6 = 1 Then GoTo calcular
GoTo inicio
As you can see I am counting in steps of 2ms the time that happens when entrance 7 is in high until the 6 are also placed in high (imagines a car that with its wheel touches to a sensor and another one later), the code counts the time that I take to him to arrive from sensor 1 at sensor 2.), of course, the result of the count would have to be a greater time to the real one due to the retardation in the execution of the commandos, but surprising the result is smaller. AID PLEASE!!!!
inicio:
GoTo inicio
contar:
pause 2
inc xx
If xx >= 250 Then
inc y
Let xx = 0
GoTo calcular
End If
GoTo inicio
