I am quite new to PICAXE and PICAXE programming, and not very experienced in programming the chips. I am trying to write a program to directly control a servo's position using an ultrasonic sensor - as you move your hand closer to the sensor, the servo rotates one way, and as you move it away, it rotates the other way.
So, could anyone tell me:
1. Would either of these actually work?
2. Which would would, in your opinion, be the best?
Thanks for any help.
symbol angle = b2
init: servo 1, 150
symbol servop = b3
symbol echo = 6
symbol trig = 3
symbol range = w1
symbol range_true = w2
label_8B: gosub SCAN
if b0< 100 then label_69
goto label_8B
label_69: gosub SCAN
pause 10
gosub SCAN2
if b0>b10 then label_D2
label_ED: let range_diff = range_true - range_true2
let range_diff = range_diff * 3 / 2
let angle = angle - range_diff
servo, 1, angle
label_D2: let range_diff = range_true2 - range_true
let angle = angle + range_diff
servo, 1, angle
SCAN:
pulsout trig,2
pulsin echo,1,range
pause 10
let range_true = range * 10 / 58
pause 50
SCAN2:
pulsout trig,2
pulsin echo,1,range
pause 10
let range_true2 = range * 10 / 58
pause 50
symbol angle = b2
init: servo 1, 150
symbol servop = b3
symbol echo = 6
symbol trig = 3
symbol range = w1
label_98: gosub
if range_true < 100 then label_6B
goto label_98
label_6B: gosub SCAN
let angle = range * 3 / 2
servopos 1, b2
goto label_98
SCAN:
pulsout trig,2
pulsin echo,1,range
pause 10
pause 50
