Greetings all,
I've used several Picaxe-18x processors for robots and have not had this problem before. When I power down my circuit I loose the program. I have the 18x connected to two L298N H-brige circuits powered at 12v. I have a 7805 regulator to power the 18x and 5 v. supply on the L298Ns. I only have a few LEDs as the L298N load, so no motor noise. I'm using clip leads and noticed a little sparking, probably because of 2000uF caps on the 12 v line and 1500uF on the 5 v line. I have a .1uF right across the 18x power pins. If I power down and come right back up, I seem to usually preserve the program. If I wait 5 minutes the program is gone. I thought the caps might be causing a surge, so I removed all but 470 uF on the 5 volt line. Still does the same thing. What do I need to do to filter the 18x? I must be missing something here.
Thanks, Theron Wierenga
Muskegon, Michigan, USA
