Graphic data from AXE110
Hi Trev324,
Welcome to the PICAXE form.
From the AXE110 datasheet:
The ‘Datalink’ communications utility is used to retrieve mission data from the AXE110 Datalogger module. The utility saves the data in CSV (comma separated variable) format files, which can be opened in all common spreadsheet applications (e.g. Microsoft Excel) for further analysis.
To load the data into Excel, from the toolbar use:
Data / Import External Data / Import Data
then locate the .csv file from the AXE110.
MS Excel contains a graphing capablity.
Use the Chart Wizard which is accessed from the typically second last button/icon on the main toolbar (the one that has the zoom control/sizing capability). See attached image of Excel screenshot
The button looks like a small graph with vertical bars but the wizard will do all sorts of graphs including dot, line, bar, pie and many more.
While not required to help with your current question, as a new member and for future reference, can I also suggest that you have a look at these threads:
post 4 at
http://www.picaxeforum.co.uk/showthread.php?t=10982
and the attachment in post 1 at
http://www.picaxeforum.co.uk/showthread.php?t=11053
