To try and get normal serin at 10400, then you need to use:
Setfreq m8
Experiment with calibfreq using positive values (up to 15)
serin pin, n/t9600 (closest to 10400), (data).
For example,
setfreq m8
calibfreq 15
serin 2, n9600, (data)
Although I'm not sure if it would work.
Only use the calibfreq command if you can easily hard-reset your picaxe, e.g. there is a picaxe reset button. Take a look at the manual on the calibfreq command for more info.
This procedure doesn't work with the 08, 18, M, and A parts, because they dont support n9600_8 baud. It is also not applicable with the 28X and 40X parts because they require an external resonator.
EDIT: hippy posted at the same time. Is it really possible to get 10400 using calibfreq?
