Hi there.
I know this must have been done before but there are so many combinations of search words I have given up.
Ok - I have an 20M with 8 inputs. I need a FAST way to convert 7 of those inputs into a Byte.
I could do it using read pin 1 + (pin 2 * 2) + (pic 3 * 4) etc but is there a FASTER (and less code intensive) way.
The concept being that I am reading the output of a HM2007 board. This board puts out via a 74ls373 the value of a recognised word. If the value is 55,66,77 then it is invalid and should not be processed.
The actual HM2007 chip sends a low pulse to the 74ls373 to output the value of the word onto the bus so I will be using that on Input 8 of the 20M as an interrupt.
I can then program the 20M to check the values to see if it is a correct word and then send it to another board via the serial bus.
Many thanks for any inspirations
Dave
Many thanks
Dave
Dave
Many thanks
Dave
