Read altitude in meters and temperature in Celcius using a Freescale MPL3115
mounted on a Sparkfun breakout board.
#picaxe 20M2
#no_data
; The MPL3115 is on a six pin breakout board from Sparkfun
; pin 1 - +3.0V
; pin 2 - Serial In
; pin 3 - C.7, nc
; pin 4 - C.6, nc
; pin 5 - C.5, nc
; pin 6 - C.4, nc
; pin 7 - C.3, nc
; pin 8 - C.2, Int2 data MPL3115 1k0 pullup needed
; pin 9 - C.1, Int1 n/a MPL3115
; pin10 - C.0, nc
; pin11 - B.7, HI2C SDL - MPL3115 1k0 pullup on breakout board
; pin12 - B.6, LCD12
; pin13 - B.5, HI2C SDA - MPL3115 1k0 pullup on breakout board
; pin14 - B.4, LCD11
; pin15 - B.3, LCD RS
; pin16 - B.2, LCD E
; pin17 - B.1, LCD13
; pin18 - B.0, LCD14
; pin19 - Serial Out
; pin20 - 0V
symbol RS = B.2
symbol E = B.3
symbol LCD11 = pinB.4
symbol LCD12 = pinB.6
symbol LCD13 = pinB.1
symbol LCD14 = pinB.0
; INITIALIZATION
setfreq m8 ;arbitrary
output RS
output E
output B.0
output B.1
output B.4
output B.6
gosub InitLCD
gosub InitMPL3115
setint %00000000,%00000010 ;interrupt low on pulled up pin C.2
; MAIN
Main:
goto Main
; MPL3115 sample complete
interrupt:
gosub ReadAltitude ; read 3 bytes of altitude, 2 bytes of temperature
gosub UpdateLCD ; display altitude and temperature on LCD
; raw data without correction
pause 10000 ; don't-flash-the-LCD delay
setint %00000000,%00000010 ; reset interrupt
; read the altitude and temperature from the MPL3115
ReadAltitude:
; I2C command values and sequence copied from Freescale MPL3115 datasheet's flowchart
hi2cin $12,(b0) ;read INT_SOURCE
if bit7 = 0 then goto RAexit ;exit if SRC_DRDY is not set
; read OUT_P and OUT_T, which also clears the DRDY interrupt
hi2cin $01,(b7,b6,b5,b9,b8)
; --OR--
; hi2cin $01,(b7) ;bits 12-19 of 20-bit real time altitude sample
; hi2cin $02,(b6) ;bits 4-11 of 20-bit real time altitude sample
; hi2cin $03,(b5) ;bits 0-3 of 20-bit real time altitude sample
; hi2cin $04,(b9) ;bits 4-11 of real time temperature sample
; hi2cin $05,(b8) ;bits 0-3 of real time temperature sample
RAexit:
InitMPL3115:
hi2csetup I2CMASTER,%11000000,i2cslow_8,i2cbyte
hi2cout $26,($B8) ;set to Altimeter with an OSR = 128
hi2cout $13,($07) ;enable data flags in PT_DATA_CFG register
hi2cout $28,($11) ;set INT to Active Low Open Drain
hi2cout $29,($80) ;enable DRDY Interrupt
hi2cout $26,($B9) ;set Active
UpdateLCD:
b0 = $01 ;clear LCD display
gosub SendCmdByte
; round up the 4 LSB of both values
if b5 > $70 then
inc w3
if b8 > $70 then
inc b9
; reformat and display 5 digit altitude in meters, 2 digit temp in C
bintoascii w3,b10,b11,b12,b13,b14
bintoascii b9,b15,b16,b17
b0 = b10
gosub SendDataByte
b0 = b11
gosub SendDataByte
b0 = b12
gosub SendDataByte
b0 = b13
gosub SendDataByte
b0 = b14
gosub SendDataByte
b0 = " "
gosub SendDataByte
b0 = b16
gosub SendDataByte
b0 = b17
gosub SendDataByte
; LCD OUTPUT
; random pin version after Hippy's 18X LCD tutorial
; b0 contains the 8 bit command or data
SendInitialCmdByte:
pause 40 ; LCD datasheet
SendCmdByte:
low RS ; send a command this time
SendDataByte:
LCD11 = bit4 ; high order nib
LCD12 = bit5
LCD13 = bit6
LCD14 = bit7
pulsout E,24
LCD11 = bit0 ; low order nib
LCD12 = bit1
LCD13 = bit2
LCD14 = bit3
pulsout E,24
high RS ; default to data byte as next char
InitLCD:
b0 = $33 ; 8bit to set 4 bit
gosub SendInitialCmdByte
b0 = $32 ; 4 bit from now on
gosub SendCmdByte
b0 = $20 ; 1 line
gosub SendCmdByte
b0 = $0C ; turn on display with simple cursor
gosub SendCmdByte
b0 = $01 ; clear the screen
gosub SendCmdByte
end
